full signal but mobile data not working
Hi :)
I have joined iD mobile yesterday. It was very easy, number was transferred across no problem. ..
But, my mobile data does not work. I've tried everything: restart phone, re-insert SIM, check my settings, APN,  everything but still doesn't work .
When I call someone it uses WiFi calling... Not the network. For example when I leave the house my phone won't allow me to make calls.
It is showing full bars, but no connection.
Please please help me if your can, I want to stay with iD but I need to solve this issue.
Thank you
Best answer by Tyler
Hey there @Nuh321, I’d certainly recommend trying a replacement SIM card via a method in my previous reply, and see if that helps.
If not, we can certainly investigate further with you.
  • 12344 replies
  • November 1, 2024
If your calls and SMS text messages are working, perhaps MOBILE DATA is turned OFF on the handset, @Nuh321.
Otherwise, maybe take the handset with your iD SIM to your nearest Currys store, go to the in-store iD kiosk and ask the advisers to help.
  • November 1, 2024
I am having the exact same problem. Had my new Samsung S24  3 weeks, am sure data was working at first. I have just been away to Germany and Netherlands, no data at all. I have checked settings and data roaming enabled. Just got back and still mobile data isn't working, I can only connect to WiFi.
Might try the popping into Curry's suggestion  if can't resolve here.
  • 4126 replies
  • November 2, 2024
Hey there @Nuh321, welcome to Community!
What’s the full postcode you’re having issues in, and what phone do you have?
Have you tried resetting network settings?
  • 4126 replies
  • November 2, 2024
Hey there @Karenh13, sorry to hear that.
If you’ve come back from abroad, and data isn’t working, then I’d recommend trying a replacement SIM card. You can get a physical SIM replacement from any Currys store, and activate it here:
https://my.idmobile.co.uk/activate-sim-outside
Or, you can contact our live-chat to have one delivered via post, or an eSIM via email:
Of course, @Nuh321, you’d be welcome to try the above also if you would like to.
  • November 2, 2024
Hi Tyler,
My phone is Google Pixel 8 Pro.
And my postcode is NE29 8PD.
Yes, I've tried everything, resetting network settings, restart phone, re insert SIM, put on aeroplane mode and take it off.
The phone recognises the SIM because it shows iD with 4 bars, but then it says no connection.
  • 4126 replies
  • November 2, 2024
  • November 2, 2024
Hi Tyler,
Thank you for the advice. :)
Here's the latest: I've put my iD SIM in 2 different handsets (1 x Samsung and 1 x Huawei) and you won't believe it, it's worked perfectly well in both phones! Calls, mobile data and texts all work.
So I realised that the issue is not with the SIM card because it's working in other handsets.
That made me realise that the Google pixel 8 Pro does not accept the iD network connect. Hence why it will only allow WiFi calling but will not allow any regular calls or mobile data to be used.
I looked at previous feedback online and another individual also had the same problem: the iD SIM was not compatible in a Google Pixel 8 Pro.
If you can take a look at this that would be brilliant :)
Daz_S
Gold Contributor
  • Gold Contributor
  • 1627 replies
  • November 2, 2024
You could ask iD for an e-sim instead, as this would have a better chance of working imho.
From the research I did several months ago for an old neighbour, it looks like the GP 8 Pro uses a different type of sim, known as a class C.
For those interested sim’s are either class A (operating at 5v), class B (3v) and class C (1.8v)
This could well explain why @Nuh321 observed the original sim from iD working in the other 2 brands of phones.
HTH
  • November 2, 2024
Hi Daz_S!
Thank you for your advice. Can you give me more information about this e-SIM you mentioned.... Sorry for my ignorance! I'm not very technical. Do you think it will work on my Google 8 pro? And how does it work if it's not a physical SIM?
Thank you 😊:)
Daz_S
Gold Contributor
  • Gold Contributor
  • 1627 replies
  • November 2, 2024
Grab a drink of your choice, put your favorite music on via some headphones and have a read:
Not sure if you need this one…
Hope these helped?
(and sorry to give you something to read rather than watching the pop, bangs and flashy lights outside lol)
edit. Yes I was able to sort an e-sim out for our friend and in that case (and I don’t want to build your hopes up) it only went and blooming worked!!
  • November 2, 2024
Haha 😅
Well I'll take your word for it and I'll try an e SIM because I don't want to change my phone.
I'll let you know if it works 👍 :)
Daz_S
Gold Contributor
  • Gold Contributor
  • 1627 replies
  • November 2, 2024
Please do 🙂
And I really do hope this sorts it for you 🤞
  • 8369 replies
  • November 4, 2024
Hi @Nuh321
It may still be worth trying a replacement SIM in this case, the Pixel 8 Pro is a device that should absolutely work with an iD Mobile SIM card, provided the device is unlocked, UK model etc.
  • November 4, 2024
Hi Tom,
Yeah I tried an email but that didn't work so I've ordered a replacement (physical) SIM to see if that works.
I'm also going to check my handset because I was 99% sure it was unlocked so I'll going to confirm that as well.
Thank you :)
  • 4126 replies
  • November 4, 2024
Hey there @Nuh321, no problem at all, we hope that helps!
Please keep us updated if needed.
