How to follow up on network issues
Hi. When in the phone I'm consistently told on every call I make that it sounds like I have a bad connection. For weeks I have been checking the network status checker for my area (post code GU10) and been met with following message each time with no further detail forthcoming. How can I follow up to find out what the issue is, when it might be solved, and if I need to change networks. Thanks
Error message on network checker: "We're fixing an issue in this area at the moment and aim to have things back up-and-running as soon as possible.
We're sorry for any disruption this may cause and will add any further updates here."
MZone
Forum|alt.badge.img+21
  • 925 replies
  • April 9, 2025
Probably best to resolve this issue by using the iD online Live Chat service, to speak to a customer adviser ​@Bjw_surrey
The advisers work until 8pm on weekdays and 6pm on weekends - just tell the 24/7 chatbot you’d like to “talk to a person”.
  • 8191 replies
  • April 9, 2025
Hi ​@Bjw_surrey
Sorry to hear this, does this issue happen in every area you’re in or just that GU10 area?
How long have you had issues here?
