i can't make calls and receive calls
  • September 25, 2024
  • 6 replies
  • 138 views
Tanzeel Zahid
i can't make and receive call i have having these issues for a few days now can you fix this
Tanzeel Zahid wrote:
I have turned volte on I still can't make any calls
  • You may need to turn OFF your Galaxy Note 8, and carefully remove the iD SIM.
  • Wait for at least 30-minutes with the device OFF and the SIM removed.
  • Carefully, replace the iD SIM in your device and power ON.
  • 12535 replies
Whereabouts is this happening, @Tanzeel Zahid
What make and model handset are you using with your iD SIM?
Tanzeel Zahid
I'm from walsall I'm using a Samsung Galaxy Note 8
  • 12535 replies
Okay @Tanzeel Zahid, looks like iD have switched OFF their 3G network service in your area.
This iD online article might help.
You’ll need to make sure VoLTE calling is enabled on your Galaxy Note 8 device.
Tanzeel Zahid
  • 12535 replies
  • 8256 replies
  • September 30, 2024
Hi @Tanzeel Zahid,
Just checking how you got on with the information provided by @andewhite.
