id mobile missing received calls
People call me, the phone doesn’t ring and the caller later tells me that it went straight to voicemail.
Happens regularly, probably about 40% of calls - although there is actually no way to know precisely how many calls I miss!
Read several similar topics on here, none of which had a proper solution (people giving up is not a solution).
Coverage area supposed to be good for 4G (BN7).
Phone is an iPhone 13 with latest software.
help please
Forum|alt.badge.img+21
  • 2216 replies
  • May 12, 2025
Hi ​@Lewesian22
We are very sorry to hear your calls are not being received.
Can you please check that your number is showing correctly in the handset?
Please select Settings - Apps - Phone- My Number.
It will need to start with +44 and not 0, for example +447123456789.
Natalie
  • May 12, 2025
Yes, it is
  • May 12, 2025
Any other suggestions?
  • 4126 replies
  • May 13, 2025
Hey there ​@Lewesian22, what phone do you have and what’s your full postcode please?
Have you tried restarting your phone, and also resetting network settings?
  • May 13, 2025
Thanks, Tyler
iPhone 13, as per post, latest OS
BN7 1BH
yes, restarted the phone, no change.
network settings reset, no change.
Network states « ID WiFi call » currently, but I also lose calls out and about.
  • May 13, 2025
Did that help, Tyler?  Any conclusions?
  • 4126 replies
  • May 14, 2025
Sorry to hear that ​@Lewesian22.
Is this an issue no matter what, when connected to 3G/4G/5G?
  • May 14, 2025
I don’t believe ID provides 5G here and I assume I’m usually on 4G.
but how am I supposed to know what I was on when I miss calls.  I miss them.
any suggestions?
  • 4126 replies
  • May 15, 2025
Hey there ​@Lewesian22, we’ll shortly send you a Private Message to your Community account so we can discuss your issue further.
  • May 20, 2025
Still waiting for any sensible suggestions to this
Siân
Forum|alt.badge.img+7
  • 1225 replies
  • May 21, 2025
We will get back to your private message on this asap.
Thanks for your continued patience.
Reply.
