iphone 15 pro slow or no data
  • October 21, 2024
  • 34 views
Recently got a new iPhone 15 pro on ID mobile. When using the data outwith wifi it is slow or non existent. It can take minutes or sometimes not load at all despite having a full 4g or 5g signal.
  • 3801 replies
  • October 23, 2024
Hey there @graelaw, thank you for reaching out.
we're very sorry to hear you're having issues with coverage.
Please take a look at both of these. If you believe you should be experiencing better signal than you are, or if the networks status checker on Three's website isn't showing any upgrades or maintenance, then please do let us know or contact us via our live-chat:
Have you also tried some of the troubleshooting methods below?
https://community.idmobile.co.uk/troubleshooting-177
