Lack of signal
Linda Coghill
I have little to no signal no matter where I go , I have checked the online signal checker and it should be perfect for 4g but i can barely use my phone.
  • 12534 replies
  • June 20, 2022
Try using the Network status checker to see if there’s a service disruption affecting your location.
If there’s an ongoing disruption it might be due to one of the following:
  1. The work three are doing to shutdown their 3G network (see here), before end of 2024.
  2. The work three are doing to roll-out 5G across their network.
You can use the Live Chat service to get more information about any works affecting you.
After connecting on the online chat, just type “talk to a person” - so you get someone in the customer service team.
The iD agents work 9am - 8pm weekdays and 9am - 6pm weekends.
Assistance is also available by contacting iD privately via their facebook page or Twitter page.
Linda Coghill
  • June 20, 2022
There us nothing been worked on and signal check show it should be good for the area,  I have done all these checks already
  • 3095 replies
  • June 20, 2022
Have you tried your SIM in a different handset? Your handset may have developed a fault.
Linda Coghill
  • June 21, 2022
No I haven't thank you , will try that.
  • 8484 replies
  • June 21, 2022
Hi @Linda Coghill
Please let us know how you’re getting on and if you’re still having signal issues!
As mentioned earlier in the thread I’d recommend checking out the coverage checker and the Three network Status Checker to double check and make sure your area isn’t having any reported issues!
