lack of signal for months.
Steven Lingwood
I complained about this subject a couple of months ago and was sent a signal strength checker link which showed signal good, but obviously not good as I still had zero bars on my phone and wife on same network had non. Well a couple of months on and still the same situation. Both my wife and myself are fed up with this situation, we are missing calls and or being cut off mid conversation due to signal. The first month with I’d was no issue at all but now it’s terrible. We are only about 4 months into a 12 month contract but seriously thinking of looking of way to cancel as a waste of time at present.
  • 12379 replies
  • October 14, 2024
Unfortunately @Steven Lingwood, the iD Mobile online signal strength checker shows a theoretical prediction of signal strength, not the actual signal for any given location in the UK.
The OFCOM mobile network signal check is often a better guide.
Try https://checker.ofcom.org.uk/en-gb/mobile-coverage.
Steven Lingwood
  • 10 replies
  • October 14, 2024
Hi, thanks for this but the data seems to be from June 24 at which time all was ok.
  • 12379 replies
  • October 14, 2024
Indeed, OFCOM data last updated on June 24, but perhaps this doesn’t necessarily mean their data changed for your location.
Maybe you can use the iD WiFi Calling service at your location (with the poor indoor/outdoor reception), @Steven Lingwood
  • 8408 replies
  • October 17, 2024
Hi @Steven Lingwood
As mentioned above, the coverage checker is only an estimate, it does not guarantee you’ll have signal in the areas it may show.
Please could you let us know the postcode(s) where you’re having issues?
Could you let us know as accurately as possible when signal went from good to bad?
Steven Lingwood
  • 10 replies
  • October 17, 2024
Hi DH3 2HY.
cant remember exact date but would be mid July.
Forum|alt.badge.img+21
  • 2255 replies
  • October 21, 2024
Thank you @Steven Lingwood
Can you please also confirm the handsets yourself and your wife are using?
Nat
Steven Lingwood
  • 10 replies
  • October 21, 2024
Hi, mine is an iPhone 11.
wifes is a galaxy s20 fe.
  • 4228 replies
  • October 23, 2024
@Steven Lingwood, is your issue with calls, texts, or data please?
Steven Lingwood
  • 10 replies
  • October 23, 2024
Calls and texts.
thanks
  • 4228 replies
  • October 24, 2024
Hey there @Steven Lingwood, when making calls/texts or receiving them and you have an issue, are you connected to 3G, 4G or 5G?
Also, do you have any bars of signal when the issues occur?
Steven Lingwood
  • 10 replies
  • October 24, 2024
It’s connected to 4g and either 1 or 2. bar max, sometimes non at all.
