Missed call alert not working
  • Helpful
  • 42 replies
I have “missed call alert” set on on my voicemail settings.
The way this is supposed to work is that if someone rings me when I am out of range (or in airplane mode) I should receive a text message alerting me when I am next in range.
This used to work but in recent weeks it has stopped working - I don’t receive any text message.
  • February 26, 2025
Hi ​@Nemo,
Have you tried disabling voicemail and re-enabling it?
It may also be worth checking your handset voicemail settings.
  • Helpful
  • 42 replies
  • February 27, 2025
I have tried switching voicemail off and switching it on again but it is still not working.
I have checked the handset voicemail settings and they are correct.
The caller hears the voicemail announcement so it is getting that far, but no text alert is sent
  • 5144 replies
  • February 27, 2025
Hey there ​@Nemo, sorry tohear that.
Has this feature worked for you previously at all with us?
How long has the issue been on-going?
What phone do you have?
  • Helpful
  • 42 replies
  • February 27, 2025
Yes it worked previously
I don’t know how long it has not been working. If you don’t get the missed call message you do not know that anyone has called you unless they happen to mention it. Most of the time reception is good so normally there is no occasion for the missed call text to be sent.
Samsung Galaxy A05s
  • Helpful
  • 42 replies
  • February 27, 2025
Last missed call text received was on 15 Dec 2024.
  • Helpful
  • 42 replies
  • February 27, 2025
So it stopped working at some point between 15 Dec 2024 and 26 Feb 2025.
  • 5144 replies
  • February 28, 2025
Hey there ​@Nemo, we’re sorry to hear that.
  • Helpful
  • 42 replies
  • February 28, 2025
I have not received any private message.
  • Helpful
  • 42 replies
  • March 17, 2025
I have been trying different options and I believe I have narrowed down the circumstances in which the problem occurs.
The problem occur if:
Extended absence greeting is on
AND
The option of not allowing messages to be left is set
AND
The caller hangs up after the personal recorded message has played and when the "I'm afraid you can't leave a message" system message is playing
All three conditions have to be present for it not to work (e.g. it does work if the caller hangs up while the personal recorded message is playing).
  • 8484 replies
  • March 17, 2025
Hi ​@Nemo
I can see we’ve responded to your private message, we’ll continue there.
  • Helpful
  • 42 replies
  • March 17, 2025
When the support line rang me they were confused about what the problem was. It turned out that the could only read the open message here, not private messages and the fuller description of the problem I put in the private post had not been passed on to them, so I thought I would repost it here.
  • Helpful
  • 42 replies
  • March 21, 2025
Just to be absolutely clear this problem is NOT, repeat NOT, repeat NOT a problem with messages being left on voicemail.
The problem is that when the voicemail system is set for the extended absence greeting and is set NOT, repeat NOT, repeat NOT to allow voicemail messages to be left, and the phone is out of range, the missing call SMS message is not sent.
The problem occurs if:
AND
The option is set NOT allowing messages to be left
AND
The caller hangs up AFTER the personal recorded extended absence greeting has already played and when the "I'm afraid you can't leave a message" system message is playing
All three conditions have to be present for it not to work (e.g. it does work if the caller hangs up while the personal recorded extended absence is playing).
  • 5144 replies
  • March 24, 2025
Hey there ​@Nemo, thank you for your update and also informing our customers of what the issue at hand is.
We’ll be in touch via PM with further updates as soon as possible.
