Mobile data not working
Steph Stephens
Been using the same phone and sim for an over a year but in the last couple of weeks my mobile data just isn’t working. It’s showing as having full strength 4g but won’t load anything. The coverage says excellent coverage in my area too
Perhaps Three UK (the iD Mobile network partner) are doing upgrade work on the cell tower / network in your location, as part of 3G shutdown.
Otherwise, there might network fault/issue in your area.
Check at https://www.three.co.uk/support/network-and-coverage/coverage
  • 12436 replies
  • July 29, 2024
Tom B
  • 8408 replies
  • August 6, 2024
Hi @Steph Stephens
Sorry to hear this, please could you let us know the postcode(s) where you’re having these issues?
Do you have these issues everywhere or just some areas?
  • September 25, 2024
My data is not working. Checked local connections and it is apparently excellent
Is there a way to reset the data settings?
  • October 1, 2024
Hi @thasee25,
Is this a sudden change?
I would advise checking the coverage and network status at the link below:
You should be able to reset your network settings via your settings.
Andre Sowik
  • December 9, 2024
Phone has suddenly lost a Data signal, No bars showing, However my daughter’s phone showing 2 bars on the same ID Mobile contract
  • December 10, 2024
Hi ​@Andre Sowik,
It sounds like it may be a faulty handset, please can you swap SIM’s and check if you have the same result with your SIM in her handset?
smkhan
  • December 31, 2024
My data isn't working when I make a phone call. I have done all trouble Shooting.
It's not my handset as I have tried other sim in the phone. How can this be fixed as I m paying money and not getting the full service!
  • December 31, 2024
Hi ​@smkhan,
Does the data not load at all?
Does your coverage change when you try and use data when on a call?
smkhan
  • December 31, 2024
It doesn't work when on call only
  • December 31, 2024
Hi ​@smkhan,
  • February 20, 2025
First my incoming and outgoing call were not working. After replacing the sim and updating my iPhones softwhere. Calls are working but internet stopped working :/
any solution?
robbo257
  • February 21, 2025
Have full coverage but no mobile data Wjy?
  • 4697 replies
  • February 24, 2025
Hey there ​@Shamoon, sorry to hear that. Are you still having these issues with data only now?
  • 4697 replies
  • February 24, 2025
Hey there ​@robbo257, sorry to hear that.
What phone do you have and what’s your full postcode please?
