Hi I joined Id mobile over a week ago. The past 2 days I’ve had one bar signal strength and mobile data is not working. Text messages are also failing to send. Phone calls seem okay at the moment. Unless I am on wifi I have no internet. Any help please?
Mobile data not working and 1 bar signal
Best answer by Michelle H
Hello
We are sorry to hear that you are experiencing issues with your service.
Please could you confirm your postcode and we’ll check the masts within your area?
Michelle
iD Mobile
Log in to the iD Community.
Social Login
