I recently joined ID mobile and I'm not realy satisfied with mobile data. It's been difficult getting any connection, even to load the simplest task of opening my loyalty card app around Slough and my home area in Yiewsley, so far, has been impossibile and I'm trying in an outdoor area on a main road. I soon as I switch to wifi everything works fine. Tried all basic, on/off, switch off data and switch back on but no change. The network coverage checker says 4g& good but i only get 1 bar. I'm not sure what to do really, Could this be some settings issues?
Log in to the iD Community.
Social Login
