My calls arent connecting
I am on a SIM only contract. Unlimited calls & text messages. I changed over to this contract in July 2020.
Over the past two days when I make a telephone call, the other persons phone rings but when they answer neither of us can hear anything nor speak.
I can hear no ringing tone nor connection either.  Please could someone advise?
Amanda Bailes
Mohammed H
  • 7962 replies
  • September 2, 2020
Hello @AmandaBailes,
Is this for all numbers or a specific number only?
What about if that person rings you?
Have you tried restarting the handset?
  • December 16, 2020
Tried switch on and off is my phone to blame or the network
Kevin M
  • 2535 replies
  • December 19, 2020
Hi there @Jeffreyc68
How long have you been having whatever problems you’re facing?
Could you detail further the problems you’re facing?
Could we get your full postcode to look into any potential known issues that could be contributing here?
  • June 10, 2021
Hi I am trying to ring a specific number from my mobile. I rang it on Saturday fine but since then when I try I just get invalid number. I tried from my partners ID mobile phone and get the same. However my friend's can ring the number fine.
I have tried to reboot my phone I have turned the Vol... off
I tried to remove the number from my phone and re adding it.
Nothing works
  • 3097 replies
  • June 10, 2021
If you tried calling the number from two different ID Mobile phones then the problem isn’t with your handset.
Enter your postcode below and check for any known issues in your area:
What are the first five numbers of the phone number you're trying to call?
  • June 10, 2021
The number is XXXXXXXXXXit has to be the network everyone I know has been able to ring from other networks
I had to get my friend to ring them for me and she got straight through
  • 3097 replies
  • June 10, 2021
I just tried calling it from my son’s ID mobile phone (pay monthly) and got a recorded message:
“The number you have called is not recognised. Please check the number and dial again.”
I can call it using my landline and Vodafone mobile phone.
So, the issue appears to be with ID Mobile.
Will R
  • 4103 replies
  • June 11, 2021
Hi @Lozza0879,
Is the number just a standard residential landline? What error message are you receiving when you try to call it?
Do you know if the number is able to call you?
Will
  • 3097 replies
  • June 11, 2021
The number is a landline, registered to a business and published on Google.
The error message can be found in my post just before yours @Will
As per my previous posts, I have the same problem when calling it from my son’s ID Mobile phone.
(No problem calling it from any other network or landline.)
  • June 11, 2021
Thank you for updating. They are a business so cannot request the call me
Will R
  • 4103 replies
  • June 12, 2021
Hi @Lozza0879,
Will
