my pixel 4a not making calls
  • 13 replies
I notice others have been told this phone is not compatible but this phone is still on the id approved list. The phone is connected to 4g.
Explain?
Best answer by Daz_S
Or this could be like the major issue with many ‘unlocked to all networks’ Samsung phones….
In those cases its the service provider software version inhibiting the VoLTE functionality on any other network apart from the original service provider or those MVNO’s that are using that providers infrastructure.
eg. An unlocked EE supplied Samsung phone will not work on iD with VoLTE - this has only been an issue since 3G was turned off across the country. The reason is the EVR software version.
You’ve already proven your phone works on O2, so my theory might be right - IDK
  • 12347 replies
  • December 3, 2024
Have you looked at troubleshooting steps in this community article, ​@Sim2
  • 13 replies
  • December 3, 2024
Yes. Pixel 4a is a supported phone.
  • 13 replies
  • December 3, 2024
Just to add tesco mobile state pixel 4a is compatible for their 3g switch off. Come on id mobile you can do better than this.
Ref https://www.tescomobile.com/help/device-help/network-and-troubleshooting/network-support/3g#compatible4gand5gphones-item-8ba6436c13
  • 12347 replies
  • December 3, 2024
Okay ​@Sim2, but some of the settings may need to be changed in order to use VoLTE (4G Calling) on the iD network with the Pixel 4a.
Unlike Tesco Mobile, iD Mobile never had a 2G GSM network infrastructure - with Tesco Mobile they’ll still have a 2G network for GSM calls after their 3G switch-off.
  • 13 replies
  • December 3, 2024
Rats.
https://support.google.com/pixelphone/thread/144589388?hl=en&sjid=15261594567304117423-EU
Google don't provide a volte function. This just socks. But did id really have to turn off 3g so quickly why not wait until 2030.
  • 12347 replies
  • December 3, 2024
Try asking the Google Assistant to turn on the VoLTE option on your Pixel phone, ​@Sim2.
All the UK mobile networks have decided to shutdown their 3G network infrastructure by end of 2025, with some doing so sooner.
  • 13 replies
  • December 3, 2024
Google assistant is same as help. Thanks
Here's the interesting bit...
https://support.google.com/pixelphone/answer/12240791?hl=en&co=GENIE.Platform%3DAndroid#:~:text=June%202022%20software%20update,Pixel%206%2C%20Pixel%206%20Pro
It is fixed in us.
Mine is way more up to date android 14 ... Can id do anything to persuade Google to send and update for their customers in UK UK
  • 13 replies
  • December 3, 2024
Google assistant is same as help. Thanks.
Volte 4g calling has been fixed in US.
My phone is way more up to date with android 14 with 5 November 23 update.
Can id influence Google to send this update to its UK customers?
  • 13 replies
  • December 3, 2024
The ironic thing is that the pixel 4a is a 5g phone.  Should id actually up up a 5g mast near me … the phone calling will work again. But oh no.
This situation is not pretty.
  • 12347 replies
  • December 4, 2024
Probably find there’s a different industry standard for making voice calls using 5G mobile network infrastructure, ​@Sim2
Did you purchase your Pixel 4a from iD Mobile?
The phone’s approved, so should work with the iD Mobile 4G Calling service (VoLTE) - once the VoLTE option is turned ON.
The Google Assistant on your Pixel device might be able to turn ON VoLTE (voice over LTE).
  • 13 replies
  • December 4, 2024
Bottom line. The pixel phones in usa were fixed up for 4g calling in summer 2022. But it needs the sims to be prepared correctly. Someone at iD has missed a step.
  • 13 replies
  • December 4, 2024
Bottom line this was fixed by google in summer 2022 in usa for pixel phones. But it also needs a setting in the sim.
  • 13 replies
  • December 4, 2024
  • 13 replies
  • December 4, 2024
  • 13 replies
  • December 4, 2024
Either way the sim needs to be prepared for pixel phones to work.
  • 12347 replies
  • December 4, 2024
Indeed ​@Sim2, without a SIM no mobile network services will work.
The Pixel 4a device works with the iD Mobile 4G Calling (VoLTE) network service, when the VoLTE option is turned ON in the Android settings of the phone.
  • 13 replies
  • December 4, 2024
So my o2 sim works fine and I can see the volte option in the pixel settings
  • 13 replies
  • December 4, 2024
The i.d sim does not enabled the volte settings. Ymmv
  • 4172 replies
  • December 4, 2024
Hey there ​@Sim2, sorry to hear this.
So when you go into settings, you have no options to choose 4G/LTE/VOLTE?
  • 12347 replies
  • December 4, 2024
Just ask the Google Assistant to turn ON the VoLTE option with your iD SIM, ​@Sim2
  • December 4, 2024
Hi ​@Sim2 ,
We are sorry that you are still experiencing issues.
Do you have the option to turn on VOLTE or LTE within settings on your phone ?
Thanks Jim
Daz_S
Gold Contributor
  • Gold Contributor
  • 1627 replies
  • December 4, 2024
