network issues
I have ID mobile esim in a pixel 9 Pro. When I first had it the network coverage didn't seem quite as good as my previous provider, however, over the last few weeks coverage seems to have got steadily worse to the point that it is almost unusable and I'm having to have several attempts to complete a phone conversation. This is both normal phone calls and WhatsApp calls. I previously had three mobile and so didn't anticipate any change in network coverage. It was noticeably not as good when I first started with ID mobile but has been really poor for the last couple of weeks. This has been both at my home address and local area and the area in which I work which is 15 mi or so away postcodes, gl5 and gl51. Can anyone help? Because I'm on the verge of having to have a second phone it is so bad.
  • 12344 replies
  • June 18, 2025
Were you using your Google Pixel 9 Pro with Three UK, ​@mattsdill
  • June 18, 2025
No I've only used that handset on ID mobile. Are there issues with the pixel 9 pro? I previously used pixel 6 and pixel 7 pro on Three, as well as Samsung's and iPhones.
Forum|alt.badge.img+21
  • 2216 replies
  • June 19, 2025
Hi ​@mattsdill
We are very sorry to hear of the issues you have been facing with the service.
Can you please confirm the following?
  • Example postcodes of where you experience issues
  • Are you connecting via 4G or 5G (if both please confirm)
Natalie
  • 12344 replies
  • June 19, 2025
If the other phones you’ve mentioned, all worked well on the Three UK network, it could suggest there might be an issue with the Pixel 9 Pro device on the Three UK network, ​@mattsdill.
  • June 19, 2025
Natalie W wrote:
Hi ​@mattsdill
Natalie
Gl51 and gl5
Both 4g and 5g
  • 4126 replies
  • June 21, 2025
Hey there ​@mattsdill, could you confirm the full postcode please?
