There is a problem in angus and tayside about 15 of us with id network have bo network the problem is your side please fix this been like this since yesterday
network problem
Best answer by Daz_S
Three UK operate and maintain the network. iD Mobile are simply a MVNO using Three’s infrastructure.
You could put your postcode in here and keep checking it yourself:
or not. I’m only offering advice 👍
Log in to the iD Community.
Social Login
