New phone, same Sim, no network connection
  • November 14, 2024
  • 146 views
Just upgraded to S24, transferred existing working SIM, plan is active, but have no connection to mobile networks or data, only WiFi.
SIM still fine in old phone!
Best answer by Daz_S
There does appear to be others saying their SIM isn’t working in their new Samsung phones too. But in those instances it’s because they went from an eSIM back to a SIM.
Anyway ​@strayner30, it might be worth asking for a new SIM, either via iD’s online channels or (probably quicker) if you pop into your local Currys. I’m aware SIMs have 3 classes/types, maybe your new phone requires a newer version?
Daz_S
Gold Contributor
  • Gold Contributor
  • 1627 replies
  • November 14, 2024
  • 3978 replies
  • November 14, 2024
Hey there ​@strayner30, sorry to hear that.
Have you performed an upgrade?
When you put the SIM in the new phone, do you have no signal or network at all?
