I cannot make calls or receive calls from home. There are plenty of signal bars and I can receive texts and data. When I try to call there is no ringing sound and after 30 secs the signal bar goes to zero, and then it says mobile network not available. The calls work as normal away from home, the phone is set on 4G, I have had a replacement sim fitted and have been on the chat three times, have been told twice “I’ll escalate this to our technical team and they’ll be in touch within the next two days” but haven’t heard anything. It would seem to me that the tower I use at home has a fault in processing my calls. Please how can I get my phone working.
No calls in home location but okay in other locations
Best answer by Tyler
Hey there
This is due to the 3G turn off that began rolling out recently. You can check if this is the case in your area below:
If you have one of the phones from the below list, then 4G VOLTE and Wi-Fi calling should be able to be selected and work, and calls should still work:
If the issue persists after following the troubleshooting above and confirming if your phone is approved, then please let us know here so we can investigate further. If your phone isn't listed above, you'll need to upgrade/get a new phone I'm afraid to receive calls. Texts and data should continue to work either way.
Reply.
