No calls in home location but okay in other locations
I cannot make calls or receive calls from home. There are plenty of signal bars and I can receive texts and data. When I try to call there is no ringing sound and after 30 secs the signal bar goes to zero, and then it says mobile network not available. The calls work as normal away from home, the phone is set on 4G, I have had a replacement sim fitted and have been on the chat three times, have been told twice “I’ll escalate this to our technical team and they’ll be in touch within the next two days”  but haven’t heard anything. It would seem to me that the tower I use at home has a fault in processing my calls. Please how can I get my phone working.
Best answer by Tyler C
Hey there ​@edwin, I have just read above and seen your issue is only with calls, and you have a Nokia 6.1. Therefore, this isn’t a supported device on our network, so calls are unlikely to work at all with this phone.
This is due to the 3G turn off that began rolling out recently. You can check if this is the case in your area below:
If you have one of the phones from the below list, then 4G VOLTE and Wi-Fi calling should be able to be selected and work, and calls should still work:
If the issue persists after following the troubleshooting above and confirming if your phone is approved, then please let us know here so we can investigate further. If your phone isn't listed above, you'll need to upgrade/get a new phone I'm afraid to receive calls. Texts and data should continue to work either way.
  • 5496 replies
  • April 8, 2025
Hey there ​@edwin, sorry to hear that. Firstly, I’ve removed your personal details as it’s a public forum, and wouldn’t want those details going to anyone else.
Firstly, can you please confirm your full postcode?
Also, what phone do you have, and hw long have you had the issue?
Is the issue only with calls?
If this has already been raised to the technical team, then we would advise awaiting further updates and keeping in touch with the same team you’ve already contacted. The technical team wouldn’t typically get in touch with you directly, you’d need to get back in touch with the same team after two-days to check for an update.
  • April 8, 2025
Sure SA62 6AP.
I have a Nokia 6.1.
I have had this issue since the 01-03-25 and yes just with calls.
The agents on the chat raised it with the technical team, that is two different agents, I have no way of contacting anyone apart from going on chat. A copy of chat transcript below.
Zaahira 9:59 AM
Thank you so much for the above. I’ll escalate this to our technical team, and they’ll look into it for you. They’ll be in touch within the next 2 days.
Gazc1964
  • April 8, 2025
I can't ring out either
  • 8256 replies
  • April 8, 2025
Hi ​@edwin,
I can’t see any issues in the area.
Have you tried the SIM in another handset? This will eliminate the issue being a handset fault.
@Gazc1964 can you please confirm your postcode for us?
  • April 8, 2025
Sure SA62 6AP
Yes I have tried another handset and another sim still no go.
Digital_Veteran
@edwin
If you have had a different SIM card, tested in a different device and it works find in other areas, it would point to an issue with the mast in your home location.
Presumably the technical team have not discovered the issue with the mast yet. Probably need an engineer to remotely check the mast.
Do you k ow any other iD mobile users in your area, are they having the same problem?
  • April 9, 2025
Thanks, yes I agree it would point to an issue with the mast in my area.
I would like an engineer to check this, please I.D. Mobile, can you arrange this or let me know who to contact.
Thanks digital veteran for highlighting this.
  • 8584 replies
  • April 9, 2025
Hi ​@edwin
Okay, taking a look the area of SA62 6AP looks to be fairly patchy, there may be some issues in the area.
You’ve tried a replacement SIM?
  • April 9, 2025
Yes tried another SIM , has worked at home for the previous few years but now only down the road
  • 8584 replies
  • April 9, 2025
Hi ​@edwin
Okay, if you’re already in touch with the team about this, we’d recommend keeping in touch with them.
  • April 9, 2025
What team ? I would like to report this fault to someone in the team how do I do this please
  • 5496 replies
  • April 10, 2025
Hey there ​@edwin, sorry for any confusion. Would you like us to drop you a PM here to discuss further?
  • April 10, 2025
I would just like to be assured that my fault is being sorted and I can use my phone at home as I used too.
  • 5496 replies
  • April 12, 2025
