No data connection after stopping WIFI
After I either go out of range of a WIFI signal or turn off WIFI I am finding that there is no data connection 4G or 5G, the only way I can restore my data is to reboot the phone, any ideas please?
Cheers
Best answer by Matthew T
Hey @delboyuk2508,
Have you tried a NETWORK SETTINGS RESET? This often fixes issues.
  • 1863 replies
  • August 2, 2024
Hey @delboyuk2508,
  • August 4, 2024
That, Mr friend, seems to have been the problem I've done a network names reset and all looks good so far, thank you for your help, cheers
