not receiving text messages
Show first post
Amber Harlow
  • May 23, 2022
sajeesh wrote:
@Michelle its not been resolved and still suffering
Hi Sajeesh, I’ve got this problem now. Can’t get into any of my banks because I’m not receiving the verification code!! Did you ever get it sorted out?!
Rory C
  • 1684 replies
  • May 24, 2022
Hi @Amber Harlow, I’d recommend contacting the FacebookTwitter or Live Chat teams so they can take a look at your account.
Rory
Sean Cragg
  • October 19, 2022
Kamilaa15 wrote:
Hi I’m having the exact same issue after i switched from vodafone. I’m doing the live chat conversation but literally getting replies once every 24 hours if that. Please can someone let me know how to resolve this, it’s getting ridiculous now😫
Did you manage to get this sorted I'm having this problem now. I also have just switched from Vodafone
  • October 24, 2022
@Dezzick3,
Can you please provide us with further information about the issue that you are having?
Sean Cragg
  • October 24, 2022
The problem I had was I wasn't getting activation codes from WhatsApp and banking app. But after a couple of days it sorted if self out
Mohammed H
  • 7962 replies
  • October 28, 2022
Glad to hear it sorted itself out!
Brian Tayler
  • January 18, 2023
Also having this issue after upgrading to a new device this week - haven’t moved provider and everything worked right up to the minute before I swapped the SIM over.
Mohammed H
  • 7962 replies
  • January 19, 2023
Hey @Brian Tayler,
Can you clarify.
If I understand correctly, you upgraded phones and now services are not working?
You should still be using the same SIM card as we don’t send out SIM cards with upgrades to handsets.
Or did you upgrade to a SIM only and buy your phone phone?
Check if the new SIM you got is active as well as testing the old.
Devadathan Balakrishnan
I  have the same issue. I could not receive OTP  SMS text message from only international bank have raised a case and the case officer said it can happen time to time. Is this been resolved to  anyone
  • July 30, 2023
Hi @Devadathan Balakrishnan,
if it’s an international number we would advise that you contact them to ensure that they are using the country code.
Hi @Kash
Yes they are using 044 before the number and I used to get the notificattions until I used to new iPhone with the same sim from ID.
Deva
  • July 31, 2023
NothappywithID
Michelle wrote:
Hi @kiraabrennan
This issue should now be resolved.
If you are still experiencing problems please let us know and we’ll send you a PM.
Michelle
How do we let you know. You’re not contactable. Advance to 7.5.23 and I’m having the same problem.
  • 12531 replies
  • November 7, 2023
NothappywithID wrote:
Michelle wrote:
Hi @kiraabrennan
Michelle
Just start chatting online at https://idmobile.co.uk/live-chat (works via a popup window in your browser).
The iD agents work until 8pm time on weekdays.
  • 8484 replies
  • November 8, 2023
Hi @NothappywithID
We’ve seen your other post and responded there.
