I recently changed and seem to be missing multiple calls despite it showing there is signal. Calls are just sent directly to voicemail. The calls have not been blocked by any apps.
I have tried to reset my network but it hadn't resolved the issue.
Best answer by Kash M
Are you able to test the SIM in a different handset at all?
I would advise contacting our Live Chat Team if you still have issues so that we can check what is going on.
