outgoing calls not connecting
  • September 18, 2024
  • 165 views
For the last few days I've been unable to make outgoing calls. When I try to call, it says 'calling' on the screen but it doesn't ring, then cuts out.
I can send and receive text messages fine
My husband is on ID too and has no issues.
Best answer by Matthew T
@LWB do you have 4G VoLTE calling on? For Samsung A14:
  1. Open ‘Settings’.
  2. Tap ‘Connections’.
  3. Tap ‘Mobile Networks’.
  4. Tap ‘4G Calling’.
  5. Make sure the 4G Calling is set to ON.
  • 1860 replies
  • September 23, 2024
  1. Open ‘Settings’.
