Padstow continued no data connection even though 3/4 bars of 4g indicated on iPhone 15
This has been consistent every time I have been in the area. 2 or 3 bars of 4g but unable to bring up anything that needs data. Including car park payment systems.
It’s very frustrating particularly as the coverage map indicates I should be receiving great service.
iPhone15 - been through the trouble shooting steps several times.
  • 4266 replies
  • April 8, 2025
Hey there ​@Chiliblue, we’re sorry to hear that.
What’s the full postcode and how long have you had issues for please?
Is the issue only with data?
  • April 8, 2025
Hi Tyler,
Well, the full postal address is PL28 8AU is my house address but tbh I am generally covered by my home broadband there. It’s more when I am out and about in a few miles radius of that postcode where I have an issue with signal.
It’s been terrible close to unusable since I changed to ID March 2024, it’s hit or miss in lots of odd places but this one really affects me as I can’t access parking apps etc.
It’s primarily data that’s the issue, voice might be problematic but that’s hard to tell as I don’t tend to receive many calls when I am on holiday here and I tend to make calls from the cottage so it has already swapped to WiFi in that situation.
Hope some of that helps. Thanks for picking this up.
  • 8408 replies
  • April 9, 2025
Hi ​@Chiliblue
Taking a look the area of PL28 8AU and the surrounding is quite weak and patchy for our signal, we’d expect issues here.
All iD Mobile plans have a cooling off period in which the plan can be returned should the signal be found to be unsuitable, as you mention having issues since joining, was this option considered?
  • April 9, 2025
Tom wrote:
Hi ​@Chiliblue
Hi Tom not sure what the point of this reply as the  cooling off period is <13 months. You are assuming that I was at what I have already stated as my holiday home to check coverage during the cooling off period (I wasn’t) I did however check your coverage checker. Plenty of the areas with weaker signal are in middle of farming land where I am unlikely to be. Signal at my address is reported as being ‘excellent’ see the attachment.
  • 8408 replies
  • April 9, 2025
Hi ​@Chiliblue
As mentioned the area of PL28 8AU looks to be fairly patchy on the map, therefore we’d expect issues in/around the area.
