Poor Signal
Hi.
I’ve recently taken out 2 sim only contracts with ID Mobile on the account that when we moved house, the coverage inside and out were showing as great. However, we have now moved and get no signal at all.
please advise on solution.
I guess you could try @Jamierbirch, but all the UK mobile operators have plenty of caveats in their terms about why they can’t guarantee their services work 100% of the time, in every location.
Unfortunately, using radio waves for signal transmission does have some inherent disadvantages.
Have you tried the iD WiFi Calling service at home?
  • 12248 replies
  • July 10, 2024
Maybe return your order/s during the cooling off period, and switch to a provider with coverage in the locations you’re using your mobile, @Jamierbirch.
Alternatively, try using the iD Mobile WiFi Calling service at home, if you’ve got a Wi-Fi network at home.
  • July 10, 2024
I am way outside of my cooling off period. I purchased these as the coverage tool assured me the new house would be fine but that is not the case.
  • 12248 replies
  • July 10, 2024
Unfortunately @Jamierbirch, the coverage tool is based on computer models that show predictions for coverage at any given location, not actual real-world coverage. Sometimes the model and reality don’t corroborate.
  • July 11, 2024
Pretty poor if you ask me. Is there anything that can be done to terminate the contract provided by ID Mobile if they can’t provide the service they said they could?
  • 12248 replies
  • July 11, 2024
  • 3991 replies
  • July 25, 2024
Hi there @Jamierbirch, welcome to Community!
Hey there @, we're very sorry to hear you're having issues with coverage.
Please take a look at both of these. If you believe you should be experiencing better signal than you are, or if the networks status checker on Three's website isn't showing any upgrades or maintenance, then please do let us know.
