Hi @Google Pixel 9
I've had such a terrible experience in my first two months of joining this network I'd like to understand my right to cancel, on the basis of ID not delivering on its side of our contract.
You could have cancelled within 30 days from the date you placed your order. The only costs to you then would have been any usage (and where appropriate the cost for returning the phone).
However, ignoring that, have you been in contact directly with iD Mobile?
If so how far did you and they go?
Have you got so far and gotten no further, did you go down the route of their complaints procedure (https://www.idmobile.co.uk/help-and-advice/complaints-procedure)?
For example I've been in London to and had not signal on the train, no signal whilst walking around near Waterloo and no signal when I go indoors (any property).
I too am having some significant signal issues myself, so totally understand just how infuriating this is. However some of your signal issues may be related to Three, and iD are a MVNO using the Three network, turning off 3G across the country. And if the areas you frequent are now void of 3G then there are some checks that you can make. Maybe have a read of this:
I'm not able to receive or make calls or get any emails, or connection to platform like Teams
The link above might solve the call problem you have, as in enabling 4G or LTE with VoLTE, though the data aspect of it might not be solved using that link.
I brought this phone for work and it doesn't allow me to do anything, unless I'm in WiF
Was this direct from iD, or Currys or Carphone Warehouse or somewhere else?
Some of my fellow customers have bought unlocked phones from places like Amazon, though it eventually transpires they are not totally unlocked.
You could also check the postcodes you use the most for known network issues:
https://www.three.co.uk/content/experience-fragments/threedigital/uk/en/site/mvno/network-status-checker/idmobile.html
And the same with the postcodes for estimated/predicted signal strength/coverage here too:
https://www.three.co.uk/content/experience-fragments/threedigital/uk/en/site/mvno/coverage-checker/idmobile.html
(On the link above you can toggle between 3G, 4G and 5G)
