problem with network when not connected to wifi
Sarah Munro
When connected to WiFi I can use all online connections, once out of WiFi it doesn’t allow me to use fb and other internet services
Best answer by Tyler
Hi there @Sarah Munro, welcome to Community!
We're very sorry to hear you're having issues with coverage.
Please take a look at both of these. If you believe you should be experiencing better signal than you are, or if the networks status checker on Three's website isn't showing any upgrades or maintenance, then please do let us know, or contact our live-chat:
  • 3719 replies
  • August 20, 2024
Candice O'Neill
My WiFi router is not connecting using my sim
  • 3719 replies
  • September 9, 2024
Hey there @Candice O'Neill, welcome to Community!
Unfortunately, we don’t officially support the usage of our SIM cards in any device other than our supported handsets listed on our website.
Therefore, we cannot confirm if our SIM cards would work in anything outside of those I’m afraid, so we wouldn’t be able to advise further other than please keep trying, or if you’re in your returns window, to return the contract.
