s24 ultra shocking wifi calling
nails350bhp
hi has anyone got a fix for s24 ultra wifi calling is turned on with logo lit up but the calls keeps dropping out as if no reception .
phone bought direct from currys
Okay @nails350bhp, your handset came from Currys and the “S24 ultra shocking wifi calling” might be down to a Wi-Fi fault in the device itself.
Anyway, the following forum topic might be helpful in this situation.
  • 12167 replies
  • May 29, 2024
What have Currys advised, @nails350bhp?
Have you selected the Wi-Fi Calling preferred option in the Settings app on your new Galaxy handset, @nails350bhp?
If Wi-Fi Calling isn’t preferred, your handset may constantly switch between trying to use iD mobile network, and the iD WiFi Calling service. Switching between the two will often cause the call to drop.
nails350bhp
  • May 29, 2024
hi I don't see a wifi call preferred only on or off .
Why would I contact currys the handset is fine
  • 12167 replies
  • May 29, 2024
nails350bhp
  • May 29, 2024
hi the problem is it doesn't seem to like turning wifi calling on so I call with very week signal when wifi calling should be switching and unfortunately I do not have the option to prioritise wifi called like on other networks
  • 12167 replies
  • May 29, 2024
Okay @nails350bhp, this forum topic might be helpful in this situation.
Unfortunately, unlike EE, iD Mobile don’t provide a Wi-Fi Calling preferred option in the settings on Galaxy handsets.
  • 8175 replies
  • June 4, 2024
Hi @nails350bhp,
Sorry if I missed it but have you tested the Wi-Fi calling using a different Wi-Fi network.
If the option isn’t available for preferred Wi-Fi you would be able to change it.
Reply.
