I have been with ID coming up to 10 years and my signal has always been quite bad but it has come to a point where it is bad in towns. I have tried switching to 3G but doesn't seem to make s difference. My postcode is PE14. Thank you.
Signal
Best answer by Tom B
The area of SA149UN should be reliable on 4G, 5G however may be quite weak or unavailable.
If you’re unhappy with your signal and have purchased recently, you may be within your cooling off period, it may be worth considering this option.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
Log in to the iD Community.
Social Login
