Signal and data issue
  • May 4, 2025
  • 68 views
Hello, I have been with ID for almost 1 year.
I always seem to have issues with my call coverage and having "4G/5G" speeds.
My bar signal is mainly on 1 bar out of 4. There is supposedly no network issue down when I check ID coverage. I always struggle to speak to people.
With data speeds, it says I have 5G and I can hardly load anything, I'm getting roughly 6mb download speed. Not enough to load a website.
I seem to have this issue in Ph13 area code. If I travel 14 miles it is still the same issue.
Does anyone have issues like this?
  • May 5, 2025
Yes the signal is terrible pretty much everywhere. I have travelled around the country and it fails everywhere. There are small pockets of around 20 meters where the speed is blazing fast lol but outside of those, nothing.
  • May 5, 2025
Have you spoke to ID, about it? Did they come back woth anything helpful if you did?
Siân W
Forum|alt.badge.img+19
  • May 5, 2025
Hi ​@Ros5  and ​@Cams  sorry to hear of the trouble you are having with coverage. Have you tried rebooting your handset, as this will refresh your connection to the mast.
Does this happen at any particular time of day or area? Is this indoors or outdoors? Do you have Wi-Fi calling enabled?
You can visit I can't use my mobile data (4G/5G) on my SIM. What should I do? | iD Mobile Community for further advise about your data, and I can't make or receive calls from my SIM. What should I do? | iD Mobile Community for call issues.
I hope these links help.
  • May 5, 2025
Yep, tried restarting, tried flight mode. Still getting low signal and low data speeds.
Siân W
  • May 5, 2025
OK ​@Cams  can you please try following all the steps on this post? I can't use my mobile data (4G/5G) on my SIM. What should I do? | iD Mobile Community
I appreciate some you have already tried.
Please let us know how you get on.
  • May 5, 2025
Yeah, i have just tried these. It is still the same.
Siân W
  • May 5, 2025
OK ​@Cams  what we can do is pop you a private message here so we can escalate this matter with our Technical Team.
