Signal issues
  • September 2, 2024
  • 147 views
Is anyone else having ongoing issues with signal?
I have an issue in my immediate  local area due to an issue with the mast, that’s inconvenient but Wi-Fi calling is getting me around it.
The bigger issue I have is when I am elsewhere, I have an iPhone 15, anything less than 3 bars and the internet is basically unusable. Calls drop frequently with less than 2 bars.
I did a fair amount of due diligence before moving to iD, checking signal in various places to see what it was like and to make sure it would work, on Vodafone 2 bars was enough to keep calls happening and data working, iD seems to be the opposite.
Is there anything that I am missing that I can do.
Before any one suggests the obvious power cycle the handset, remove the SIM, flight mode on/off etc, I have done all of these things,
Best answer by Kash
Hi @dancingbear84,
It sounds like you may need a replacement SIM but it’s worth testing the SIM in a different handset first.
Please contact our Live Chat Team and they can send out a replacement.
  • 8175 replies
  • September 5, 2024
Hi @dancingbear84,
Weronika Bialas
I have the same issue . Problem with signal at home and outside. Had better in other countries when been on holiday...
