Signal worse since switching from 3
  • September 25, 2024
  • 6 replies
  • 331 views
I switched from 3 to iD and my signal has got noticeably worse at home. Same phone & nothing else has changed. I live on the edge of a large estate, a stones throw from a retail park. Is there a way to report this or get it checked? Thanks
  • 12167 replies
Try the OFCOM online coverage checker for UK mobile operators, @Scarlet Pimpernel.
https://checker.ofcom.org.uk/en-gb/mobile-coverage
Thanks, that confirms we have got a poor signal now but is it possible something has changed? The whole area where approximately 20,000 people live is poor & the last update was in June
  • 12167 replies
  • September 26, 2024
Anything is possible, @Scarlet Pimpernel
Perhaps Three UK are working on 3G network service shutdown in your area, which might impact network services prior to the actual 3G switch OFF in your area.
  • 8225 replies
  • October 1, 2024
Hi @Scarlet Pimpernel
As @andewhite suggests, the 3G switch off is taking place and may affect your area, it’ll be worth checking the below;
Thanks but have checked the list & all appears to be in order on my (Samsung s21 5g) phone & 3G hasn't been turned off here yet. Allegedly i should have an 'excellent' 4G signal inside & out & even a 5G signal outside but i get 1 bar 4G at best & have never found 5G anywhere near by. Same on my wife's Google pixel. Only conclusion is the maps are a lie
  • 8225 replies
  • October 4, 2024
Please could you let us know the postcode(s) where you’re having issues?
The maps themselves are estimates, not exact 100% guarantees.
If you do experience issues early on in your plan with signal all iD Mobile plans have a cooling off period in which to return, it may be worth considering.
