Sometimes phone won't connect
  • September 13, 2024
  • 66 views
Geoffers3040
Sometimes a phone call won’t connect. There is silence rather than a ringtone but the seconds counter works and then call cuts out after 20 seconds.
Phone is Samsung A34. My wife's is identical and this morning connected to Curry’s when mine wouldn’t when ringing the same number.
Best answer by Kash
@Geoffers3040,
Please can you check that VoLTE is enabled on your handset?
As 3G is being turned off we require customers to enable 4G calling.
I can’t see any issues in the area so if the above doesn’t work, please test the SIM in another handset.
  • 8408 replies
  • September 17, 2024
Hi @Geoffers3040
Sorry to hear this, how long have you been having these issues?
How are texts and data?
Geoffers3040
Hi Tom, I am not sure how long to be honest. It has occasionally happened in the past, a few weeks or months I would say, but seems more often now.
It does not affect texts or data as far as I am aware.
Geoff
  • 4175 replies
  • September 20, 2024
Hi there @Geoffers3040, what’s the full postcode you’re having issues in?
Geoffers3040
LN22PL
  • September 24, 2024
@Geoffers3040,
