Switched to ID, 4g but no signal
Switched to ID pay monthly with an e-sim. Ported over my old number but have no signal at all, anywhere, unable to make or receive phone calls, even on wifi with wifi calls set to on. Despite this, I still somehow have 4g/5g, running at a reasonable speed. I’m on an iPhone 13, running the latest version of iOS and supposed to be in an area with great signal. Have restarted phone multiple times, reset network settings etc with no result.
Best answer by Tyler
Hey there @Bonobojim, welcome to Community!
Please try the following:
  • 12403 replies
  • June 14, 2024
Sounds like the number might be blank in Settings > Phone > My Number@Bonobojim
The online coverage checkers are just a theoretical prediction of signal strength at any given location - actual signal strength can be better or worse.
Perhaps try the iD online Live Chat for help. The advisers work until 8pm on weekdays - the iD chatbot works 24/7.
Tell the chatbot you want to “talk to a person”.
  • June 14, 2024
Aha, it is showing as blank - anything I can do that doesn’t involve a hour long wait on the live chat?
  • 12403 replies
  • June 14, 2024
Okay @Bonobojim, I’ll assume you know your number, so try adding it yourself in the Settings app on your iPhone - starting with “+447” etcetera.
Once that’s done - restart your iPhone.
  • 4266 replies
  • July 2, 2024
