unable to receive calls on iphone 16pro
  • February 18, 2025
  • 90 views
Hi, I just bought an iPhone 16pro and switched to ID Mobile with an E-sim. Today they completed the switch but I am unable to receive phone calls. I am currently abroad (Italy).
can you please help?
thanks
Antonio
MZone
  • 1204 replies
  • February 18, 2025
Your number will still port over to iD as usual on the date you’ve chosen, but it may not work abroad, as you need to be in the UK for the SIM to begin working correctly.
They usually advise to complete a port when in the UK to avoid any problems.
MZone
  • 1204 replies
  • February 18, 2025
Your number will still port over  as usual on the date you’ve chosen, but it may not work abroad, as you need to be in the UK for the SIM to begin working correctly.
  • February 19, 2025
I also have the same issue in the UK.  Technical team recommended a  change to physical SIM today which they will post to your address. I secured one today from a Curry Store which hasn’t resolved the issue but you may have more luck.
Forum|alt.badge.img+21
  • 2215 replies
  • February 21, 2025
Hello ​@doddant
We are sorry to hear you are experiencing issues with using the service.
Are you still currently abroad, if yes, when are you due to return to the UK please?
Nat
