Hi , both me and my wife are on ID and for the last 2 weeks whenever making a call we can't hear the other person and vice versa, the call either goes quiet , sounds stuttered or sounds like.its under water , we have had to resort to watsapp calling but have missed important incoming calls due to terrible quality , we have tried restartingphones and checking for updates but still having the same problem , it only seems to effect ID calls and not calls through over sources Eg watsapp and fb messenger, many thanks
very poor quality phone calls for 2 weeks
Best answer by Daz_S
What tends to happen is although you’re on Wi-Fi the SIM is still affected by the signal strength and when the signal drops too low it causes the Wi-Fi call to drop, ask me how I know…..
However, there is a workaround for this - Enable Wi-Fi calling → toggle Airplane/Flight mode ON → toggle just the Wi-Fi back on → WiFi calls are no longer affected by the dropping mobile signal and you should find that as long as you’re in range of the Wi-Fi the calls should be fine.
Just remember to take it out of Airplane/Flight mode when your leaving the Wi-Fi network.
Log in to the iD Community.
