Best answer by Daz_S
Hi Daz and Tyler, thanks for getting back so quickly. In answer to your questions, Daz:-
- We were in Greece and the phone worked fine, although I'm sorry but I didn't notice if VoLTE was still showing as I wasn't looking for this at the time
Honestly its no problem.
Hmm. My wife and I used our phones in Spain, Portugal and France and when we got back we had some significant issues obtaining an iD signal - I’m beginning to think using roaming is somehow messing the SIMs up. My next step would have been as andewhite suggests - getting another SIM. Personally I would (if you can) pop down to your local Currys and ask them for a replacement as its a quicker process.
You then need to activate it
- I checked the coverage and it isn't showing any problems at the moment
- I had already tried connecting to another network, then reconnecting to id with no luck. I have just tried again, but with no luck. I have checked the settings again and it is still showing that VoLTE is enabled, but I am still not getting the symbol in the top right corner and the signal is still weak
Okay, well that’s another positive regarding any known issues
Another thing that might be worth trying is to swap SIMs in both of your phones. As they’re direct from Samsung both should work. If you do decide to do this turn the phones off, eject the SIM, swap them and then power the phones back up. If the problem moves (which I’m sure it will) it’ll rule out your phone having an internal problem.
Now having said that sometimes the previous number is remembered by the phone (in honesty this has only ever happened with iD) and should you then put the correct SIMs into the correct phone and the number is wrong when should be able to sort this out too - but by turning the phone off this should mitigate this
- I have thought about WiFi calling, but haven't tried it yet. I assume that this would still come from my id allowance rather than BT, my internet provider? (I don't have a phone package with BT so don't want to end up being charged by them!)
Yes it uses your minutes allowance off the phone. If your BT internet is unlimited then there’s no worries there. It basically routes the call via the internet instead and therefore works in poor signal areas (but you need to be connected to a WiFi network and WiFi calling is only for use in the UK)
Ideally, I would prefer to sort this out without WiFi calling as I'll probably have the same problem outside the home. My battery is low now, so will do as Tyler suggested and contact chat tomorrow.
And hopefully that’s what we’ll eventually be able to do.
