Wifi calling & Samsung S23 Ultra
James Sampson
Wifi calling not working on my S23 Ultra. All software up to date, wifi calling enabled on the device etc. Unlocked phone direct from Samsung. What else can be done as the standard cell signal is poor and calls are next to impossible?
Has Wi-Fi calling ever worked with your S23 Ultra, @James Sampson?
Have you tried a NETWORK RESET on your handset?
  • 12167 replies
  • May 21, 2024
  • 8175 replies
  • May 22, 2024
Hi @James Sampson ,
Just checking if you managed to check the advice that @andewhite provided.
If you still require assistance, please let us know.
James Sampson
  • May 22, 2024
Thanks - have tried that - after resetting it generally (although certainly not always) connects over wifi (based on the S23 icon) but sat still in the same position it disconnects after <1min and is temperamental
  • 8182 replies
  • May 27, 2024
Hi @James Sampson
Okay, are you able to enable flight mode and then try?
James Sampson
  • May 27, 2024
Tried forcing it on aeroplane mode and can't make/receive any calls either 🙄
Lauren
Forum|alt.badge.img+19
  • 479 replies
  • May 31, 2024
Hi @James Sampson, is it possible to try a different SIM card in the phone to see if you’re still experiencing the same issue or not?- We understand this isn’t always possible, but it’s worth trying if you can.
-Lauren
