Wifi calling not working on my S23 Ultra. All software up to date, wifi calling enabled on the device etc. Unlocked phone direct from Samsung. What else can be done as the standard cell signal is poor and calls are next to impossible?
Wifi calling & Samsung S23 Ultra
Has Wi-Fi calling ever worked with your S23 Ultra,
Have you tried a NETWORK RESET on your handset?
Log in to the iD Community.
