zero call coverage
I have been having signal issues for over a month now which is very frustrating. I have calls which start and then cut out and carry on or calls that just cut off. I.have checked my coverage and its really good so insure what the cause is.
  • 12531 replies
  • April 4, 2022
Hello @mamunro81,
Have you checked for any service disruption of ongoing maintenance and repair activity in your area?
Check for this using the three network status checker
Anyway, good luck.
Rory C
  • 1684 replies
  • April 7, 2022
Hi @mamunro81, just checking in to see if you managed to use the service checker posted above? What were the results?
Rory
