is there issue with Mobile data?
no mobile data. i have tried to reset the network by choosing a different network then reconnecting to ID but still no mobile data.
Best answer by Tom B
Hi @brik
Hey there, we're very sorry for any disruption, we are aware of the issue/outage and we are currently working on this as a high priority. We hope to have this resolved as soon as possible. Thank you for your patience with us.
https://community.idmobile.co.uk/announcements-16/service-update-network-issue-and-problems-accessing-the-id-app-58108
Tom B
  • 8434 replies
  • February 12, 2024
Hi @brik
  • 8 replies
  • February 14, 2024
I've an issue with mobile data as well and not due to the recent outage.
It concerns WhatsApp. When using my phone get messages. Pop up on lock screen, sounds, all notifications work. If I put phone down and the screen turns off then after a couple of minutes I do not get any notifications. It is as though it loses network connection. On WiFi it still works when screen off. Phone is Samsung S21. Latest update, latest WhatsApp version. Checked app settings against another Samsung, all are the same, including notification settings. Reset network. No difference. All worked fine on Sky before switching to iD.
Anyone any ideas before I leave ID?
  • 12451 replies
  • February 14, 2024
Did notifications work okay before the latest Android update, @Hatter?
  • 8 replies
  • February 14, 2024
Yes they did but was on another network then. Other phone on talkmobile works fine. All settings are the same for both phones. Only difference is the network provider.
  • 12451 replies
  • February 14, 2024
I think WhatsApp notifications are sent over a network connection (mobile data or Wi-Fi) to the registered device, @Hatter
If your S21 + iD SIM gets WhatsApp notifications over a Wi-Fi network connection, then perhaps there’s a mobile data specific device setting, which is preventing notifications while the lock-screen is active.
I’m not an Android user, but In iOS there are plenty of Settings > WhatsApp > Notifications options, with many mentioning the lock-screen.
Otherwise, maybe issue is related to a mobile data usage or power-saving settings, which prevents WhatsApp notifications to the lock-screen?
  • 8 replies
  • February 14, 2024
Hi @andewhite.
I've tried the sim in a phone that does receive lock screen notifications and it didn't get any. So it seems to be somewhere on the network that is causing the problem. I read on another thread where someone said to switch adult content filter off. That worked for them. So waiting for ID to switch it off. It is pending atm.
  • 12451 replies
  • February 14, 2024
Okay, hope turning OFF your account’s adult content filter works. WhatsApp doesn’t appear to be a typical adult content service - anyway, good luck @Hatter.
  • 8 replies
  • February 14, 2024
No, still the same issue with it turned off.
  • 8 replies
  • February 14, 2024
Oops forgot to say, thanks for your help.
Tom B
  • 8434 replies
  • February 15, 2024
Hi @Hatter
I’m unsure that the network itself would have any restriction or similar to WhatsApp notifications coming through, hopefully the suggested Adult Content Filter toggle works.
  • 8 replies
  • February 15, 2024
Good news! Checked the services section last night and adult filter was still pending. So no WhatsApp messages. This morning the filter has been turned off. Whatsapp messages now come through on lock screen. So definitely something to do with the adult filter.
Thanks everyone for your help.
Maybe admin could put this fix as a sticky.
Tom B
  • 8434 replies
  • February 16, 2024
Hi @Hatter
Glad to hear that’s helped.
  • 8 replies
  • February 20, 2024
Thank you.
Why the adult filter causes the issue is strange but at least working now.
Tim22es
  • August 5, 2024
Hi I have a TP link mifi and recently opted for the 70gb monthly package, I have installed the SIM and it's been happily working away, have now arrived in France and have no data, it shows on my phone as connected but no internet access, getting annoying as I have data roaming on, on both mifi and SIM, running out of ideas. Any help welcome tia Tim
Tom B
  • 8434 replies
  • August 12, 2024
Hi @Tim22es
Have you tried the iD Mobile SIM card in a supported device?
It’s worth noting we don’t officially support any routers or dongles at this time, therefore usage of a SIM card within one may not work as expected.
