need help. calls not working
Kelly Burrows-Smith
Can't receive or make calls
Is your iD account pay monthly or PAYG, @Kelly Burrows-Smith
Is there a network fault in your area?
Check for faults at https://www.three.co.uk/support/network-and-coverage/coverage?tab=2
  • 12550 replies
  • May 1, 2024
  • 8256 replies
  • May 4, 2024
Hi @Kelly Burrows-Smith,
Just checking if you have seen any improvements or if the issue is still ongoing?
If you could provide further information about the issue/errors we can check it out.
