HELP
  • December 12, 2024
  • 37 views
Kirstie Whibberley
I have just moved my number over from Vodafone, my iMessages do not work. I have followed all the steps. However when entering my number into the phone settings it will not save. This needs to be rectified as soon as possible.
Best answer by Tyler
Hey there ​@Kirstie Whibberley, sorry to hear that.
Please try the following:
If the above doesn’t work first time, please try the above steps again, but with the phone in flight mode. If not working still, please try the above steps in order one more time, with the SIM outside the phone, then restart the phone.
  • 12344 replies
  • December 12, 2024
Have you tried to use the RESET NETWORK option on your iPhone, ​@Kirstie Whibberley?
The Apple iOS user guide explains all the reset procedures for iPhone devices.
For example, with iOS 17 or later:
Settings > General > Transfer or Reset iPhone > Reset > Reset Network Settings
  • 4126 replies
  • December 12, 2024
