message/ring out problem
Vanessa66
Primary says no service & won’t ring out & I can’t text message on my new iPhone with eSIM, any suggestions please?
  • 2959 replies
  • May 24, 2025
If you see ‘Primary’ as the line, then you have more than one SIM/eSIM installed on your device. Do you pay for and use two separate mobile phone plans?
Vanessa66
  • 8 replies
  • May 24, 2025
no, just got the eSIM, no SIM card at all
Vanessa66
  • 8 replies
  • May 24, 2025
Also, I’ve just erased everything from my old phone, if that makes a difference?
  • 2959 replies
  • May 24, 2025
Are you using an iPhone?
Vanessa66
  • 8 replies
  • May 24, 2025
Yes, iPhone 15
  • 2959 replies
  • May 24, 2025
Then you definitely have more than one eSIM (or an eSIM and physical SIM) installed. The option to choose the primary line is only available when multiple eSIM’s/SIM’s are installed.
Settings > Mobile Service
Post a screenshot of the above menu option
Vanessa66
  • 8 replies
  • May 24, 2025
  • 2959 replies
  • May 24, 2025
Yea, you have two eSIM’s installed. SIM 1 has no service, SIM 2 has full bars of signal.
Turn off the eSIM marked as ‘Primary’ and see if you still have full signal displayed in the top right corner of the screen. If you do, delete the primary eSIM!
Vanessa66
  • 8 replies
  • May 24, 2025
I have this now
Vanessa66
  • 8 replies
  • May 24, 2025
3 bars , can’t send screenshot 🤷🏼‍♀️
  • 2959 replies
  • May 24, 2025
You need to delete that old deactivated eSIM and configure your phone correctly.
Vanessa66
  • 8 replies
  • May 24, 2025
If I delete the old eSIM, will it automatically configure correctly?
thanks
  • 2959 replies
  • May 24, 2025
Yes, but I recommend that you reboot the device after deleting the old eSIM.
» Make sure you delete the old eSIM and not your active iD Mobile eSIM.
I recommend that you configure your iPhone as shown above as you need to check that you still get a mobile signal. If you do, then the eSIM configured as ‘Primary’ is indeed the old eSIM and it is this eSIM that needs to be deleted.
Vanessa66
  • 8 replies
  • May 24, 2025
I’ve deleted & everything seems good so far, I can text & ring out 😊
thankyou so much 👍🏼
  • 2959 replies
  • May 24, 2025
Vanessa66 wrote:
thankyou so much 👍🏼
You’re welcome! 👍
  • 4126 replies
  • May 26, 2025
Hey there ​@Vanessa66, we’re glad to see that ​@WelshPaul’s expert advice was able to help! Thank you ​@WelshPaul.
Please let us know if any further questions.
