I am abroad and did not set-up Roaming before leaving, help?
  • February 14, 2019
  • 1161 views
I am abroad i did not activated the roaming. Help me to activate my sim card.
Thank you.
Best answer by Mohammed H
Hello @kstavros,
I've merged your 3 posts into one thread of it's own.
Please refrain from spamming the Community over multiple topics regarding the same issue.
We'd be happy to help you set-up Roaming.
Which country are you Roaming in?
There are a few steps for this.
We've put this all into one topic here: https://community.idmobile.co.uk/topic/show?tid=182&fid=48
I've extracted the relevant information for you:
Turn on Roaming in the iD account
Learn more
If you want to use your iD phone abroad, you’ll need to make sure that roaming’s enabled on your account. Here’s how to do this:
• Log in to the app or My Account.
• Select ‘Services’.
• Toggle ‘Roaming’ on.
Turning on Data Roaming on your handset
Learn more
Data Roaming would also need to be turned on in the handset.
The steps for this can vary for each handset but this is generally found in the Settings under Mobile Network.
If you're unsure, you can use our Get your settings tool which will guide you through this.
Just head to: https://www.idmobile.co.uk/help-and-advice/get-your-settings/settings-tool
Then enter your handset make and model.
Click the Configure your phone manually tab and then Connectivity Settings.
Select How to enable Data Roaming from the list of results and follow the steps.
Highlighting each step will show a picture guide.
Configuring the correct Access Point Name (APN) settings.
Learn more
You'll also need to ensure you're using the correct APN settings.
In most modern smartphones, when you first insert a SIM into the handset, settings are retrieved automatically from the network.
Since iD Mobile use Three UK masts, this can sometimes lead to the Three UK APN settings being retrieved.
They will work fine when in the UK, but when abroad, you may have issues roaming.
To fix this, just add a new APN with the correct settings as follows:
APN: id
Username:
Password:
MMS Proxy: mms.idmobile.co.uk
MMS APN Username:
MMS APN Password:
MMS Port: 8799
If you're unsure how to do this, you can use the Get your settings tool from the link above and follow the steps found under Configuration Settings and then choose ID Internet Settings from the list.
Please note, not all handsets have the ability to configure APN settings.
You'll be able to log into your iD account by heading to https://my.idmobile.co.uk/
Let us know if you're still having issues.
  • February 14, 2019
Hi, there
Thank you.
  • February 14, 2019
Hi, there
Thank you.
  • February 14, 2019
Hi, there
Thank you.
Gregor
Helpful
  • Helpful
  • 1061 replies
  • February 14, 2019
Hi @kstavros
You can activate roaming within your ID Mobile App. I would recommend you to find a place with free wi-fi available and access your account.
Then tap "services" on the bottom of your screen and look for the option as shown of the picture below.
If that doesn't help I would recommend contacting Live Chat team so they could have a look for you what can be done there.
Regards
Mohammed H
  • 7962 replies
  • February 15, 2019
Hello @kstavros,
Learn more
Learn more
Learn more
APN: id
Username:
Password:
MMS APN Username:
MMS APN Password:
MMS Port: 8799
  • February 20, 2019
Thank you so much, I've got a roaming now!
Ryan D
  • 4571 replies
  • February 21, 2019
That's great @kstavros! Let us know if you need anything else.
