Incoming Text while roaming
  • January 28, 2020
  • 136 views
Hi all,
    I’ll be on roaming (india) soon, are there any charges to recieve a incoming text (this could be a OTP or some text from a friend in U.K)?
    The link https://www.idmobile.co.uk/help-and-advice/international-and-roaming-charges states only texts to charges while you are in roaming country.
    Is it to be considered as free of charge?
Best answer by Mohammed H
Hey @jainvikas8,
Receiving texts is free no matter where you are in the world. (As long as we support roaming in that country).
This is why there’s no charge on it.
Mohammed H
  • 7962 replies
  • January 29, 2020
Hey @jainvikas8,
  • Helpful
  • 22 replies
  • January 29, 2020
It would be good to document this somewhere. Thanks for the reply.
Kevin M
  • 2535 replies
  • January 30, 2020
Hi @jainvikas8
We’ll pass your comments over to our Web Team as feedback, if it isn’t listed already then we should hopefully be able to get this updated.
