Best answer by Mohammed
Are you having any issues with making calls/texts when abroad?
What network are you showing you're connected to?
One key thing I often advise users to try is to delete all of the current APN settings.
Then add fresh new ones with the ones outlined in the linked topic.
This can often reset you on the network and seems to work most of the time.
Have you tried manually connecting to a network?
