Mobile data not working [Roaming]
I’m having problems whilst in Spain with mobile data. Although it is switched on both on my phone and in the app, unless Wi-Fi is available it tells me it is disconnected. I don’t know how to make it work so any suggestions will be great fully received.
Best answer by Mohammed H
Hi @Eildon ,
Are you having any issues with making calls/texts when abroad?
What network are you showing you're connected to?
One key thing I often advise users to try is to delete all of the current APN settings.
Then add fresh new ones with the ones outlined in the linked topic.
This can often reset you on the network and seems to work most of the time.
Have you tried manually connecting to a network?
View originalAre you having any issues with making calls/texts when abroad?
Log in to the iD Community.
Social Login
