Using my phone in Australia
  • February 15, 2019
  • 1064 views
Blogs19
What costs for using iPhone on ID in Australia and will it work out there?
Best answer by Gregor
Hi @Blogs19
I can confirm that roaming will work in Australia
Here is the tablet with all the costs
Also if you would like to check any of the prices for any other country in the future just head to this address.
Regards
Gregor
Helpful Contributor
  • Helpful Contributor
  • 1061 replies
  • February 15, 2019
Hi @Blogs19
Regards
Blogs19
  • February 15, 2019
Thanks. Is that £1.68 per call or per minute for calls within Australia?
Gregor
Helpful Contributor
  • 1061 replies
  • February 15, 2019
Hey @Blogs19
It is a cost per minute.
Regards
