Hi, I took out a contract with ID mobile on an iPhone 11 & ported my phone number from another network to the phone. I now cannot send text messages. I have checked the iMessage settings but they have the number I was given before my number ported over still listed. I’ve tried signing in & out again of iMessage but it makes no difference. I don’t know how I change this number to my number that I ported across. Can you help please?
Texts won’t send
Best answer by Will R
Can you please check under the “My Number” setting on your handset that the number you ported in is displayed please? i suspect it isn’t, and if that’s the case, please change it to reflect the desired number and let us know how you get on.
Will
Log in to the iD Community.
Social Login
