Illegible bills
My bills are illegible. There must be a fault with the ID system. I’ve only just took a contract out with ID, and my first two bills are just a load of symbols? Not a good start…
Best answer by Kash
Hi @SirCharles,
We can’t advise on this, however bills can be viewed using a PDF viewer.
For the meantime we would advise following this step until the issue is fixed.
  • Helpful
  • 17 replies
  • November 1, 2023
Mine are the same I sent a screenshot someone on the help topic and never heard anything back
Geluk
Silver Contributor
Forum|alt.badge.img+10
  • Silver Contributor
  • 452 replies
  • November 1, 2023
Try to read the pdf on a device other than your phone; eg laptop/ pad etc.
  • Helpful
  • 17 replies
  • November 1, 2023
I will try later today as I am just going to work thanks for your reply
  • 12248 replies
  • November 1, 2023
Okay @Ethan p 2015, if you’ve got an iPhone running iOS 17+ a workaround is to install the Adobe Acrobat Reader app for reading PDF files.
  • Helpful
  • 17 replies
  • November 2, 2023
I’ve just looked at my bill on my apple iPad and the bill is fine but it is still unreadable on my iPhone
  • 12248 replies
  • November 2, 2023
Are your iPad and iPhone running the same versions of iPadOS and iOS @Ethan p 2015?
  • Helpful
  • 17 replies
  • November 2, 2023
Yes
  • 12248 replies
  • November 2, 2023
Ethan p 2015 wrote:
Yes
Perhaps the PDF issue only affects iOS @Ethan p 2015 - not iPadOS.
Do you know the OS version number running on each device - iPhone and iPad?
  • Helpful
  • 17 replies
  • November 2, 2023
My bills used to be fine it only started going wrong in September
  • 12248 replies
  • November 2, 2023
Apple introduced new PDF features in iOS 17 in September, which appear to cause problems viewing the iD bill PDF with the iD app.
Looks like you’ll have to use a workaround - like your iPad - until iD fix their iOS app.
  • Helpful
  • 17 replies
  • November 2, 2023
Thanks for your reply it’s not really that important to me to view my bills as I have monthly sim only deal
  • 8352 replies
  • November 3, 2023
Hi @Hobo & @Ethan p 2015
Unfortunately there is an issue with iOS/Apple devices with reading PDF bills at the moment, there is no fault on iD Mobile’s side and we cannot fix this ourselves, Apple will need to look into this.
For the meantime, as suggested above by @Geluk & @andewhite, you’ll need to use a PDF reader or a different device.
  • November 10, 2023
I’ve got unreadable bills on IOS and Macos. However I found a work-around, on the Mac open the PDF bill in Word - you can read/print it OK then.
SirCharles
  • January 15, 2024
Why is this still a problem?!
  • 8352 replies
  • January 16, 2024
Hi @SirCharles
We’d recommend contacting Apple directly to ask this.
  • 8192 replies
  • January 21, 2024
Hi @SirCharles,
